2.5 Rock Krawler Advice
Old Nov 18, 2012 | 05:17 PM
Dusty11's Avatar
Default 2.5 Rock Krawler Advice
Looking to put a 2.5 Rock Krawler Max Travel on my 11 JKUR and run 35s. The question is with using it primarily as a DD and use around the farm and trails do I need to install gussets?
Old Nov 18, 2012 | 05:53 PM
Mark's Avatar
It really just depends how hard you will wheel it. 35's are a heavy tire and can bend the weak danan 30 C's after a bit of use. The gussets are a pretty cheap insurance. If you cant weld them on yourself any shop would do it for $100 or so.
ps- you think you'll go easy on your DD, just as I did. But you will only want to go harder. Build it right the first time cause it only gets more expensive from there on out.
Old Nov 18, 2012 | 06:24 PM
palehorse's Avatar
Mark is correct.
I run the same kit, same size tires, 2013 JKUR... I chose to go with just the Artec front LCA skids and Artec inner C Gussets. They all fit fantastic!
Get them welded on at the same time as you get the RK rear trackbar bracket welded in place. It cost me $270 labor (3 hours) plus parts... but, I do think it's worth every penny for the peace of mind!
Old Nov 18, 2012 | 06:42 PM
EzK's Avatar
EzK
I've been running that set up(gusset free) since April.
After 6,000 miles and 5 trips to Rausch Creek my c's are intact as far as I can tell. However, if I had the time and money I'd get the gussets for the added insurrance.
Old Nov 18, 2012 | 07:31 PM
TheTerminator's Avatar
You're basically getting them for peace of mind. There are no scientific studies to show that they're absolutely necessary.
Old Nov 18, 2012 | 07:38 PM
Dusty11's Avatar
How's that play out taking it into your local dealership for warranty work? Are they like Gussets, your flagged now or what?
Old Nov 18, 2012 | 07:44 PM
palehorse's Avatar
Not mine. Hell, my salesman is the one who referred me to a good welder.
He also arranged for a free front-end alignment at the dealership after I installed my RK lift and new shoes, so I think I'm good to go!
Old Nov 18, 2012 | 08:00 PM
Dusty11's Avatar
That sounds reassuring, and like you had one heck of a good salesman and dealership.
Old Dec 20, 2012 | 03:12 PM
lulu2533's Avatar
Mark is correct.
This might be a stupid question but, I thought this kit was 100% bolt on...why the welding of the trackbar bracket?
Old Dec 20, 2012 | 03:14 PM
EzK's Avatar
EzK
For added strength. I drove a month without welding and it was fine but ill take all the strength I can get.
