Shock question!!!!!!!
Old Nov 18, 2012 | 06:41 PM
roecker's Avatar
Default Shock question!!!!!!!
I installed new Bilstein 5100s on my 2012 JkU yesterday. Well today when I was ordering the steering stabilizer, i decided to verify that the shocks 4 Wheel Parts sold me in store were correct.... (should have done that before install) Well turns out the fronts are correct (2.5-3.5" lift) but the rears are for a 4-5" lift..... Should I exchange them asap? Or is there a hidden benfit to having the longer shocks? Thanks in advance.
Old Nov 18, 2012 | 06:54 PM
k0260's Avatar
The benefit will be more travel/flex. You may however need to extend brake lines, add bump stops, etc. I just swapped out my 5100's for 3" lift for Fox remote res 4"-5" lift so I could get max travel.
Old Nov 18, 2012 | 07:05 PM
roecker's Avatar
Thanks for the quick response! I don't really do any rock crawling or anything. Mostly beach and trails. So I guess I can just leave them and check the droop amount?
Old Nov 18, 2012 | 07:09 PM
k0260's Avatar
I'd leave them in case you decide to lift your jeep more. Just if you do go crawling where you'll be articulating the suspension, the rear could stuff your tires pretty far into your wheel well. Should be good though, for peace of mind you could add bump stops, they're affordable and easy to install.
Old Nov 18, 2012 | 07:29 PM
TheTerminator's Avatar
Without spring retainers, you can run into "a bit" of a problem if your extra long shock drops and the short spring pops out.
I also believe the longer shock will have different compression/rebound characteristics.
Old Nov 19, 2012 | 05:56 PM
roecker's Avatar
Well today I picked up the 5100 series stabilizer and also decided to keep the rear shocks. I am going to be getting the Evo plush ride 3" coils in a week or two and will install coil clips when I install those coils. Thanks for the advice guys
Old Nov 19, 2012 | 06:01 PM
k0260's Avatar
nice, I'm hoping to pick up the 3" plush coils to replace my crappy Rough country coils in the next couple weeks too.
Old Nov 19, 2012 | 06:18 PM
roecker's Avatar
Ha, I am replacing my Skycrapper coils.... SUCK
