Question about running "Fortys"
Old Nov 20, 2012 | 03:10 AM
Default Question about running "Fortys"
Will 4.88 gears be enough in a 6 spd.?
Do i need front/Rear Pro-rock 44's OR should i go to to PR60's?
Thanks for any help...
Old Nov 20, 2012 | 03:24 AM
nick99wj's Avatar
4.88's would probably be ok, but 5.13's or 5.38's would be better. Also for 40's i would def go with 60s front and rear, or at a minimum 44f/60r
Old Nov 20, 2012 | 03:47 AM
Gotcha.....what about driveshafts?
Will the stock Rubi 4;1 be OK with the 40's?
Old Nov 20, 2012 | 04:06 AM
JKingAround's Avatar
Stock 44s will be fine just add 35 spline chromoly axles and gusset it. 5:13 or 5:38s gears would be best with a 3.8 or 3.6. Now if your going to raise your power output with a turbo, supercharger or hemi I would suggest going to D-60s if you hardcore wheel.
