37 x 13.5 x 17 Toyo MTs on 17 x 7.5 Stock Wheel???
Is anyone running this combo of stock rubi wheels 17 x 7.5 with 37 x 13.5 x 17 TOYO MTs ??? Seems like a 12.5 width tire is the limits on a 7.5 wheel, but???? Would the 13.5 TOYO be too wide? Let me know what your experiences are...
With a 12.5" tire your suppose to have a 8" wide rim minimum. People do run them on stock 7.5" rims but you have to watch running to low of air. And I would figure they cup and wear out the mid of the tread first.
Don't know about the toyo but I have bfg 35x12.50's on stock 18x7.5 and I have a set of 325-60r18 (33x13) on stock 18's as well and the 13's look to be the limit on that size wheel but that a 33 on 18's, 37's on 17's with a lot more side wall might be ok but the issue would if you air down on the trail you might pop a bead
Hey Jake - never heard of your place before. I'm in Morris County also and you're about 20 minutes from me. I checked out your site, you have good prices. Do you do installs? Maybe send me a PM and introduce/explain some details. Would like to maybe swing by as well and check out your shop(assuming you have one that is).
I run 12.50's on the 7.5" wheels and they are fine, but honestly I wouldn't go any wider than that. As it is, the sidewalls are pretty much flat, but lowering the air pressure has them wearing good. I would go with a 12.50 tire, or a wider wheel
Soooo... looks like the stock 7.5" wide rims are out. Should I go with 8" or 9" wide? I'm leaning to 9" since it seems the 8" is suggested for 12.50" wide tires. The TOYO MTs are 13.50".....
