1" lift- What size tire will I be able yo run with a 1 inch body lift kit?
My budget is tight and I can only afford a 1 inch body lift and was wondering the biggest tire I would be able to to run with the lift. If you have pictures please post! Thank You!!!!
Originally Posted by swaite3
I have a 1.25 bl and 1.75 coil spacer front and .75 rear and clear 35's offroad no problem
Bl w/rear bumper bracket $99
Coil spacers $45
Coil spacers $45
Originally Posted by MarbleheadGuy
Would strongly recommend waiting til you could get at least a 2.5" budget boost for about $150. Will give you much more flexibility than a body lift and you can run up to 35s easily.
So for backspacing, you can either run wheel spacers if using the stock wheels or buy after market wheels with 4.25 or less back spacing for 35s.
Hope this helps.
