Sway bar touching coil???
Mine is a lot closer on the passenger side. I'm not sure how you can fix it. I noticed the springs on my JK fit snug around the lower perch so there isn't any way to adjust the spring.
Are the springs bowing forward on your Jeep?
Your pictures are exactly like mine are! On the passenger side I can easily fit my fingers between the spring and sway bar but on the driver’s side I cant. I don’t think it has anything to do with an alignment because I just had one done after I installed the pr44. Like yours my springs are all the way against the grove in the axle on the bottom so there is nothing that can be done with that part. I have adjustable upper and lower control arms and by looking at it mine it would be much worse if I didn’t have as much caster dialed in as I do. I have the unlimited axle so I have 6.0 degrees of caster and if it were down at like 4.0 that would make it even closer to the sway bar. It looks like it’s a spring issue on mine I cant think of what else it could be.
