Where is the vent on a manual trans at?
Old Nov 24, 2012 | 08:51 AM
JKingAround's Avatar
Default Where is the vent on a manual trans at?
I found the
Old Nov 24, 2012 | 08:52 AM
I found the transfer case I can't find the Transmision. It's the 3.8
Old Nov 24, 2012 | 10:34 AM
Bump ......
Old Nov 24, 2012 | 11:10 AM
vandegrift's Avatar
You need to remove the shifter boot, and the rubber liner boot under that. You will find the vent, on the side of the shifter bolt down plate on the top of the trans. It has a plastic vent cap on it, and if you pry too hard, you will break it, just be careful.
If you are going to run the vent up higher, you may also want to consider replacing the clutch disc, as they are prone to detonation if it is submerged in water, and you engage/disengage the clutch with the engine running.
I am looking into an aftermarket one myself...
Old Nov 24, 2012 | 11:28 AM
Centerforce make one that fits there's a thread about it.
Old Nov 24, 2012 | 01:09 PM
vandegrift's Avatar
That is the one I've been looking at.
Old Nov 24, 2012 | 01:54 PM
If you don't shift in the water you'll be alright. I'm going to wait ether until it goes or I throw a diesel under the hood.
