Got 2k to spend on suspension jeep noob any advice
Old Nov 25, 2012 | 06:52 PM
wishithadahemi's Avatar
Default Got 2k to spend on suspension jeep noob any advice
Hey guys i have been saving for a while now for a suspension for my 2012 unlimited rubicon.First thing it's my daily driver and will not be a hardcore rig just want something that I can have some fun with once and a while .first I don't wanna have to replace my front drive shaft so 2.5" would be my max height I'm currently running 285/70/17 with 17" with 4.75" bs .I plan on running 35's once the 33's need replacing .I also plan on running a lod mid width style bumper with a 8-9.5k wench and a poison spyder rear bumper.
I know if the 2.5 aev duelsport but to me to order that threw northridge4x4.ca with the geometry brackets and a aev procal is almost $1500 without a discount so if there is something more rugged for cheaper plz tell
Thx again Troy
Old Nov 25, 2012 | 07:03 PM
chaz14_9's Avatar
I have a 4 inch OME suspension lift kit on my JKU and didn't need to replace the drive shaft.
Old Nov 25, 2012 | 07:11 PM
teamgreen666's Avatar
have you looked at rock krawler lifts? the 2.5 flex system and some fox shocks would be very nice for around $1600
Old Nov 25, 2012 | 08:24 PM
Ya I seen those i have herd there pretty rigged 2.you can also upgrade components with those unless it's another system .I'll. Have to check them out
What year is your jk?
Old Nov 25, 2012 | 08:26 PM
I thought anything over 2.5" lift on 2012 auto will require a thinner front drive shaft due to exhaust contact and premature wear due to high joint angle?
Old Nov 25, 2012 | 08:27 PM
big dr's Avatar
You mentioned northridge 4x4,,, dave loves the old man emu lifts, and i had one on my 97 tj. Loved it, and the price was right. I'v also seen them on JK's, they work and flex great! good luck with your decision!
Old Nov 25, 2012 | 08:30 PM
This dan fellow work at the canadian northridge in penoka Alberta ?.I have seen guys quote his name before not sure if it's The I.s store .But thx I hope I make a good choice also
Old Nov 25, 2012 | 10:22 PM
FlameRedJK's Avatar
Rock Krawler!!
I paid about 2k for my entire lift with shocks.
3.5 X-Factor with Bilstein 5100
Old Nov 26, 2012 | 03:46 AM
chaz14_9's Avatar
It's a 2008. I believe the whole kit was around 1600. Not quite sure because I won it in a giveaway from Northridge. I have had it on for about 6 months with absolutely no problems. It's a great lift, rides awesome.
