Rock Krawler 3.5 and Synergy high steer Help!!
I installed a 3.5" Rock Krawler lift on a 2013 JKU and recently added an Synergy High steer kit. The kit came with a track bar relocation bracket ( Mounts to axel and raises track bar). My track bar seems like its to high now not sure if I need that bracket or not??? Thanks Shawn
did the steering kit also come with new drag link?
The high steer kit allows for the drag link to be mounted on the top of the knuckle rather than on the bottom like the stock DL. The track bar bracket pushes the track bar up an equal amount so they remain parallel to each other. If you did not also "flip" the drag link then, yes, using that track bar bracket will have the track bar up to high.
If you are lifted over 3", the drag link flip can help out quite a bit; however, if your DL and TB are parallel and you don't have any problems...no real need to flip.
If you are under 3" of suspension lift, the drag link flip will cause problems as your DL will make contact with the frame as you begin to stuff the passenger tire.
Pull a string from center of each bolt eye in the trackbar and measure the angle of the string. Do the same for the drag link if there is a bend in it as well. This will give you a better reading and allow you to compare angles.
I appreciate your help on this!! I measured the track bars and the drag link using the string method and got 5 degrees on all three. So this leads me to believe. Prior to installing the draglink flip kit that my track bars where not parallel?? That would mean Rock Krawler produced a lift with unparalleled track bars!!
