Teraflex 2.5 coil lift?
Old Nov 28, 2012 | 11:24 AM
aftermath's Avatar
Default Teraflex 2.5 coil lift?
Will the teraflex 2.5 coil lift level the jeep out? I have a 2013 jku. I will be running there shocks also
Old Nov 28, 2012 | 11:27 AM
durrettcustoms's Avatar
I'm going to run the same setup on my 07. My understanding is if you want to level the jk you should run the front leveling spacers, especially if you are running a front bumper and winch. Then again I'm just staring at my parts for now and have not tested for myself!
Old Nov 28, 2012 | 11:47 AM
BossHog's Avatar
It leveled mine out perfectly.
Old Nov 28, 2012 | 11:50 AM
mpkelley20's Avatar
It definitely levels the jeep at first but you may get some sag over time. Especially if you add heavy bumper and winch so spacers can help like an earlier poster mentioned.
Old Nov 28, 2012 | 12:34 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Just add some 1/2" coils spacers in with the kit if you plan on a heavy bumper.
Old Nov 28, 2012 | 12:40 PM
fellstar's Avatar
I added 1/2 front and thought, even with my Rock hard4x4 full width bumper and winch, that she was nose up. Ended up with a 3/4 in the rear to level the 1/2 in the front out.
Old Nov 28, 2012 | 12:58 PM
aftermath's Avatar
I don't plan on any heavy bumpers for a good while. Just adding the 18inch wheel on 33 to the spare tire carrier. So I should be good without spacers correct? Or should I get 1/2 inch spacer for rear?
Old Nov 28, 2012 | 02:07 PM
Kalamari's Avatar
I got the Teraflex 2.5" coil lift and put spacers in the rear. I like the factory rake because I often put heavy stuff in the back and hate it when the ass end droops.
Old Nov 28, 2012 | 04:59 PM
courtsm3's Avatar
+1 , i like some rake as well. levels her out when it matters
