Bestop Trektop nx instal help!
Trying to instal my new trektop and its not goin to good. Seems to be a big gap on the front left and right sides of the windshield
And the zippers for the rear window are no where close the the side zippers. Its almost 6" on both sides
Any ideas or help would be awesome
Take off the rear windows and flip the top open. Then:
1. start the top zipper (2 inches)
2 start the window zippers (2 inches)
3. then tuck the window panels in, starting with the door surrounds and working your way around to tailgate.
When new, these tops are a pain in the ass to install, especially when cold
Edit - Is your front gap with the latches closed? Mine has a gap, but I don't have any leaks there
It will loosen up slightly over time. Big factor is the outside temperature though!
Important steps are to only start each zipper 1 - 2" and then work your way around once you have them all started.
The top needs to be this tight since it does not have a frame.
I had the same problem in 90° weather..... If u just play with it, and figure out which way works best for u..... I just start the zippers before pulling the top tight then after the top is snapped into place I zip the windows up.... Still hard to do but not bad.... Good luck!
Sent from my Samsung Galaxy Tab 10.1 using Tapatalk 2
