Front Dana 44 re-gear
I have regeared axles in the past but its been awhile. In the past when i did the regears i was the one to take the old gears out. I was able to measure the stock shims, and use those numbers as my starting points for the new gears. This time i got the axle and everything was already removed. The axle is off a 2008 Rubicon. Its the front dana 44. The axle comes with 4.10's and im regearing to 5.13's.
If someone has done this regear, and has some numbers i could work with. The driver/passenger side carrier shim sizes, and the pinion shim size that you used. I know that the shim sizes vary from axle to axle, i just want something to work with.
Also I know on older dana 44's the carrier shims were behind the bearings, is it true that these dana 44's have the shims on the outside?
