Hub rings really necessary?
Old Dec 6, 2012 | 12:28 PM
jadmt's Avatar
JK-Forum Ambassador
Default Hub rings really necessary?
I bought a set of Raceline Raptor 981's and the hub bore is 78.3mm and the stock wrangler hub on my 2013 jku is 71.5mm one of the Vendors Motorsport tech makes custom hub rings but they are $25 a piece so seems kind of high and they are made from aluminum and I know aluminum has a tendancy to gall onto steel so I am worried that they would not hold up. Are they necessary or not? I am running 265/75-16's so not big rubber and my tire/wheel combo is about 75lbs. One thing that makes me a little nervous is the raceline raptors have to use a pretty slim lug nut as they are recessed. Any thoughts?
Old Dec 6, 2012 | 01:15 PM
TxRdStr's Avatar
Anytime can run hub-centric you are better off than lug-centric, the pressure is on the hub direct and it is truly centers. Lug centric the lugs have all the pressure on them and not always going to be perfectly crnterd. So I would say yes for 100$, get them.
Old Dec 6, 2012 | 01:31 PM
SiliconTi's Avatar
Yes, you need them.
Make sure the ring and hub are spotlessly clean, then use a liberal amount of Never-Seize on them both and you'll be good to go.
Old Dec 6, 2012 | 03:03 PM
jadmt's Avatar
JK-Forum Ambassador
didn't take much convincing I ordered a set. I guess $100 really is cheap insurance in the long run.
Old Dec 6, 2012 | 04:00 PM
EzK's Avatar
EzK
Originally Posted by SiliconTi
Yes, you need them.
False.
They aren't needed.
Old Dec 7, 2012 | 06:29 AM
jadmt's Avatar
JK-Forum Ambassador
Originally Posted by EzK
False.
They aren't needed.
after doing as much research as i could and just not liking how small the lug nut clamping area was on the Racelines I think I made the right choice and while they may not be 100% necessary I could not find there is no downside and only positives from using them.
Old Dec 11, 2012 | 07:30 AM
SiliconTi's Avatar
I feel they are needed. I'd rather keep it as hub centric as possible. If you lose a lug or they loosen up, the wheel will still run true.
Old Dec 11, 2012 | 10:21 AM
EzK's Avatar
EzK
Yeah, it's definitely all positives. I wouldn't advocate not doing it. Just don't want to worry those without them.
Old Dec 27, 2012 | 03:19 PM
jadmt's Avatar
JK-Forum Ambassador
follow up the rings arrived today (3 weeks since ordering) they look quality and fit very snug which I think is the point. I know I feel better having them on.
without
with
Old Jan 12, 2013 | 03:51 AM
Idaho's Avatar
Wise investment...
