front axle 65.5 rear 68.5 ok?
Old Dec 9, 2012 | 09:00 AM
jp chen's Avatar
Default front axle 65.5 rear 68.5 ok?
i will put on front prorock 44 and put on rear prorock 60 what wide is better?
front and rear 65.5 or front 65.5 and rear 68.5 is better?
thanks
Old Dec 9, 2012 | 07:42 PM
tattedfire's Avatar
If anything you'd want the front to be wider than the rear. This keeps your turning radius tight. If your rear is wider than front you will have a shit turning radius. Add wheel spacers to the front to match the rear at least if you have to.
Old Dec 9, 2012 | 11:38 PM
rtguy1's Avatar
order the front pr44 at 68.5", so when you do a 60 in the rear they will be the same. u do know u can get the pr44 in alternate widths, right?
Old Dec 10, 2012 | 10:26 AM
tattedfire's Avatar
Yes, forgot about that. Order the front at 68.5". Trust me you'll want your axles at 68.5" wide. Just plain looks badass!
Old Dec 10, 2012 | 06:07 PM
big dr's Avatar
Not only does wider look better,, it is more stable! To me,, that is very important considering your jeep gets increasingly less stable with lift. I went 68.5 front and rear. Very happy
ID:	397110   Click image for larger version
ID:	397111   Click image for larger version
ID:	397112   Click image for larger version
