How do you brake in a new winch cable?
Old Dec 10, 2012 | 06:07 AM
Jsjeepjk08's Avatar
Default How do you brake in a new winch cable?
Ok so I had to get a new cable for my winch. What's the best way to brake it in before I have to use it? Iv read a lot on this and I see lots of things about it I'd just like the eazyist way to do this thank you
Old Dec 10, 2012 | 06:35 AM
Biggy's Avatar
Hook up to a tree preferably on a slight incline or set your park brake two or three clicks and spool it up evenly making sure not to overlap the cable.
Old Dec 10, 2012 | 03:20 PM
Gman*2007's Avatar
I had mine on an incline and attached the hook of the cable to a parked truck. Then I winch mine in with the jeep in neutral under a load making sure the cable did not over lap.
Old Dec 10, 2012 | 04:07 PM
Maertz's Avatar
Damn didnt know i was sposed to. Should have read the directions. I guess getting stuck was my first time breaking it in
Old Dec 10, 2012 | 04:29 PM
Jsjeepjk08's Avatar
Thank you guys I'm going to have to do this really soon. Before I have to use it agin. Dose any one know what could happen if this didn't happen first?
Old Dec 10, 2012 | 05:16 PM
JeepingNet's Avatar
What can happen is the cable could push the lower wraps aside and jam itself under lower wraps when the pressure is released.
My old house I had a perfect tree on a slight incline.
Tighter the better but it's more important to have it loop correctly so it's a fine balance
