Will series 98 15x10 with 3.75 BS rub calipers on 2012 JKU Sahara?
I just got off the phone with a salesman from 4wd trying to order some new tires and wheels. I told him what tires I wanted ( 33x12.5x15 Duratrac), and before I even mentioned what rim I wanted (Series 98 Rock Crawler 15x10 with 3.75 BS), he was quick to tell me that they will not fit my Sahara or a Rubicon because of the larger calipers. Now, I've read various posts on various sites and it seems that this particular wheel should fit. Tires should not matter, correct? I would just like to hear from someone that has my same vehicle and has the same wheels/tires. I really like the way this combo looks and really don't want to spend much more to have to go to a 16 inch rim. If anyone can help I would greatly appreciate it. Thank you.
OK, since obviously nobody has this setup, I guess I will go with 16 inch wheels. The problem is that I am really set on the duratracs and the width of the 12.5 inch tire. I cant seem to find a close enough equivalent. It seems like they are all around 11 inches. Why is this? Are there any other tires that are 33x12.5x16 that anybody can recommend?
Update: Just got my pro comp 98's 15x10 and 33x12.5x15 duratracs. Wheels fit perfectly and looks awesome. No grinding whatsoever. However, the wheels stick out a good 3 inches past the fender which looks awesome but I definitely need to order my 2.5 inch lift. I'm gonna put up some pics in the gallery in the next few days when I'm feeling better.
