What wheel can I install 285/70R17 Nittos on?
Old Dec 16, 2012 | 10:20 AM
R.C's Avatar
R.C
Default What wheel can I install 285/70R17 Nittos on?
I've been searching high and low,but cant find a direct answer that i need.So,that being said,I have a 2012 Unlimited Sport w/ 373 gears,2.5" Teraflex suspension w/ Bilstein 5100 series shocks.Can i install some 285/70R17 Nitto Trail Grappler M/T on the 17x7.5 stock wheels with no rubbing or spacers? If not,what back spacing and/or offset will i need to look for on a after market wheel? Also,what width is best to accommodate these tires?
Old Dec 16, 2012 | 10:22 AM
k0260's Avatar
I ran 295 70 17 Nitto Terra grapplers on my stock 17's, needed atleast 1" spacer to avoid rubbing when flexed. I used 1.5 spacers and worked great.
Old Dec 16, 2012 | 10:26 AM
Ncb's Avatar
Ncb
Check the manufacture's spec sheet for wheel width. I had KM2s in that size on 17X8 wheels with 4.5" back spacing with out any rubbing. Those tires will rub on stock wheels and no wheel spacers.
Old Dec 16, 2012 | 10:55 AM
R.C's Avatar
R.C
295 is like a 34"?
Old Dec 16, 2012 | 10:57 AM
R.C's Avatar
R.C
I checked and the width on my stock wheels are 7.5"
Old Dec 16, 2012 | 11:00 AM
Ncb's Avatar
Ncb
Meant to say check the specs for the tire for what wheel width is recommended.
Old Dec 16, 2012 | 11:18 AM
R.C's Avatar
R.C
Originally Posted by ncb
meant to say check the specs for the tire for what wheel width is recommended.
p255/75r17
Old Dec 16, 2012 | 11:34 AM
JEE73's Avatar
I have Bridgestone AT Revo's in that size on my stock wheels. No issues.
Old Dec 16, 2012 | 11:37 AM
k0260's Avatar
I'm now running up to a 315/70/17 on OE Grand Cherokee wheels that are same specs as all Jeep 17's, 17" X 7.5".
Old Dec 16, 2012 | 11:47 AM
R.C's Avatar
R.C
Thanks for the reply,but I've seen several post stating no rubbing or spacers on different tires,but i really like the Nittos.Several friends run these tires on their F-350's for their construction/oilfield business and in their daily driving.The pull trailers up to 10,000#'s.The hold up well and get great mileage out of them. Thats why i'm looking for info on these certain tires.
