How often to check bolts?
Old Dec 20, 2012 | 10:29 PM
jeepfreakjk's Avatar
So I was wondering how often do u guys check that your suspension and steering bolts are tight? I noticed a clunking from the front end stopped and my upper sway bar bolts were loose I installed a teraflex 2" leveling kit about 30,000 km ago I checked all bolts at 20k km and sway away bar links are loose after 10k km? so should I check them every 10k km?
Old Dec 21, 2012 | 02:41 AM
jacksup's Avatar
check mine when i a doing oil channge and tire rotation, blue lock tite good idea as well
Old Dec 21, 2012 | 05:04 AM
Firelyle's Avatar
Same here.....
Old Dec 21, 2012 | 05:44 AM
hneiper's Avatar
Yup. That's when I check mine. But I also check before and after a wheeling trip.
Old Dec 21, 2012 | 06:44 AM
Rob 12B1P's Avatar
Mine have come loose a couple times now, thinking about drilling and pinning or wiring the bolts. I usually check torque after every wheeling trip.
Old Dec 21, 2012 | 11:56 AM
I was actually thinking of this as well
Old Dec 21, 2012 | 12:05 PM
dethinator's Avatar
I check every time i am under the jeep, which is quite regularly! Found two loose lower control arm bolts one of the times, could feel the axle moving under braking.
