Im a girl, i need help!
Old Dec 21, 2012 | 04:07 AM
Jeepergirl09's Avatar
Default Im a girl, i need help!
First time having a 4 wheel drive vehicle. Thought it was a simple motion of pulling back lever. Not so much, I fir fired that out this morning when I needed it. (Lots of snow).
So how Do I put my vehicle in 4 high?
2012, unlimited sport
Old Dec 21, 2012 | 04:12 AM
bob-o's Avatar
Yes u should put it in 4 hi so u can still drive a faster than 20+ mph. 4 hi will allow u to drive up to 55mph but probably should if there's a lot of snow
Old Dec 21, 2012 | 04:22 AM
How do I do that?
Old Dec 21, 2012 | 04:23 AM
How do I put it in 4 high?
Old Dec 21, 2012 | 04:27 AM
jdk's Avatar
jdk
If it is really hard put the tranny in N at a slow roll push the 4WD lever to the right and pull back. Should pop right in.
Old Dec 21, 2012 | 04:34 AM
Will give tht a try. Thanks!
Old Dec 21, 2012 | 04:36 AM
When I was a dealership they were able to put it in 4hi at a stopped position? How do I do that? What gear do I need to be in?
Old Dec 21, 2012 | 04:44 AM
jdk's Avatar
jdk
You should be able to put it in 4WD at a stop but if it is really hard try it with the transmission in Netrual.
Old Dec 21, 2012 | 04:47 AM
Jkcarmelindy's Avatar
You can also be moving at about 5mph and pull back to 4hi or disengage.
I have manual tran if it is hard I put in neutral
Old Dec 21, 2012 | 04:55 AM
Rob 12B1P's Avatar
For 4W high just pull the lever back, it shouldnt take much effort if its working right.
