Did I miss anything?
Hey everyone I was about to pull the trigger on some upgrades to my 2011 2dr JK..here is a list of what I'm going to be ordering. I'm just curious if I missed anything so I don't get the process held up at the shop.
My main concern from reading the forums though is if I need to upgrade my drive shaft right now. I don't mind spending the money getting it done right the first time so any suggestions on a good upgrade would be great.
My list for now till I get extra money to blow..er invest. If anyone has any suggestions of additional things I need I'm all ears.
Suspension: 3" Suspension System with Full Flex Arms
Wheels: Mickey Thompson Classic III, 17X9 with 5 on 5 Bolt Pattern
Tires: Mickey Thompson 35x12.50R-17LT, Baja ATZ Radial
Extras:
Bushwacker Flat Style Fender Flares
Spare Tire Spacer
Extras:
Spare Tire Spacer
might want to look into getting brake line extensions or drop down brackets and bigger bump stops.
Depending on theyear you have you might need the exhaust spacer. I believe if you have a
(11-12) then youwill need the spacer. Anything else is optional like bumper, drive shaft etc. but with a
35 you may wanna look at getting a rear bumper with a tire carrier or the teraflex HD hinge kit.
Good luck! and post picture when everything comes in and set up!
Lets see off the top of my head: frame mounted sliders, C gussets, Chromoly Ball Joints, Chromoly axles, steering stabilizer relocation, evap relocation or armor, front axle truss or sleeves, LCA armor, rear shock mount armor, and better front and rear diff covers.
You dont need an exaust spacer for an '11.
