Let the mods begin...2011 JK Sahara
Thanks! The work was worth the reward, but let me tell you the SmittyBuilt roof rack was not a direct bolt on...not even close. In fact, unless you have a grinder and cut off wheel or two I wouldn't suggest doing it yourself...otherwise the whole setup went on pretty good and I ran a relay for the two new lights triggered by the oem bright lights switch and those babies burn at least twice as bright as oem lights if not 3 or 4 times!
