Does the JKS Jspec 2" coil lift need...
Old Dec 27, 2012 | 05:13 PM
Jumpmaster's Avatar
Default Does the JKS Jspec 2" coil lift need...
...a trackbar relocation bracket, brake line drop brackets or anything else other than maybe 2" bumpstops if I plan to run 35's? I am pretty sure these springs will net more than 2" on a 2 door. I really like the looks of this kit (coils, front/rear LCA's, adj. Front track bar, and fixed length sway bar links) and JKS products are well made. Other than new shocks is anything else needed to make this package "complete". Thanks much.
Old Dec 27, 2012 | 08:30 PM
JJ_jk001's Avatar
Mine netted about 3". I added a trackbar just recently and now I feel it needs control arms.
Old Dec 27, 2012 | 08:46 PM
Delux2769's Avatar
I would suggest making your own brake line drop brackets. Much cheaper that way.
Old Dec 27, 2012 | 09:09 PM
courtsm3's Avatar
i have the JKS 2.5' front and rear coils with fox shocks. i used teraflex bumpstops, zone rear sway bar end links ( stock rears went up front ) , teraflex HD rear track bar bracket, bilstien 5100 front stabilizer and pro comp front track bar. i just added 3/4' front and rear spacers to give me 3.25' of lift but my jeep is more like 3.5' total. jeep drove fine before the spacers, but now with the spacers i need front CA's or brackets to improve the ride. sharp or dramatic bumps I'm starting to feel more than before. JKS coils ride very well, but like any lift you will need a good shock to maximize the ride.
