Metal cloak bumper and warn Zeon?
So I have a metalcloak front stinger bumper about to be installed on my jk. I want to purchase a warn Zeon 10S winch to put on it. I am just curious if anyone might have that combo so I know it will fit. I have already contacted metal cloak and they cannot give me a definitive answer because they just don't know. It's probably a long shot, but figured I would check here before I pull the trigger. Thanks for any help!
Not sure about the metal cload bumper fit. But I just put the Zeon 10s on my Poison Spyder Brawler Lite front bumper and it just fit. Apparently, the Zeons are a bit longer/wider than the 9.5cti - end caps are also thicker - i.e don't taper as much as the others. Mine needed the "lift from the hawse plate that mounted underneath the winch so that the ends would clear.
The Warn web site lists the size specs. I believe that it will depend on which Metalcloak winch plate you get as far as center or offset fairlead mounting. I am using a Metalcloak bumper with a Warn Powerplant and the size is close to the Zeon. The Powerplant uses an offset farilead, and I believe the Zeon will require a center fairlead mount. The PP is wider by a little, but the Zeon is deeper by a little. It is gonna be close on the Zeon depth, but I think it will fit.
