aev procal failed to update my 2012 jkur
Old Dec 28, 2012 | 04:54 PM
jetmechabq's Avatar
Default aev procal failed to update my 2012 jkur
Today I had my 5.13 R&P installed and my procal failed to update transmission controller. We tried to use 3 others and hey also failed to update. Has anyone else had this problem if so how did you fix it? Going back to 4.10's is not an option.
I forgot to mention that I'm getting fault code P0730 for the gear change. And then the transmission lock out reverse and goes into limp mode.
Old Dec 28, 2012 | 07:06 PM
JRWid's Avatar
I just completed my 2013 build with the AEV Procal - had a problem with the TPMS feature, called AEV and they suggested pulling both the pos and neg cables from the battery for 2 hours so the system fully resets. 2 hours later - worked like a charm.
Old Dec 29, 2012 | 06:06 AM
jetmechabq's Avatar
i'll give it a try more to follow.
Old Dec 29, 2012 | 03:58 PM
jetmechabq's Avatar
Ok it work so far!!!!! THANKS
Old Dec 29, 2012 | 06:16 PM
JRWid's Avatar
Glad to hear it!
