Looking for advise on my lift kit
Old Dec 29, 2012 | 12:29 AM
Omani2010's Avatar
Default Looking for advise on my lift kit
PLEASE HELP!!!
THIS IS THE LIFT KIT
ALL FROM TERAFLEX
-2.5' JK SPRING LIFT
-SHOCK STEERING STABILIZER
-SHOCK KIT JK FRONT AND REAR 2.5'
I ALSO GOT THE SPIDERTRAX SPACERS INSTALLED FRONT AND BACK
NOW GOT THE 'DEATH WOBBLE' NOT SURE IF ITS THE SPACERS DOING IT
I WILL BE CHANGING THE STOCK 16' RIMS TO RUGGED RIDGE 17' BY TOMORROW
AND WIDER TIRES JUST WONDERING IF I SHOULD GET RID OF THE SPACERS ??/
PLEASE ADVISE....
Old Dec 29, 2012 | 12:39 AM
dogsonparade's Avatar
Check your torque specs?
Did you follow the instructions to the T?
Old Dec 29, 2012 | 02:34 AM
scooby snacks's Avatar
Agree, your control arms, track bar, sway bar links must be torqued to spec. I have the same kit and never had a problem.
Old Dec 29, 2012 | 08:38 AM
Omani2010's Avatar
Thanks taking her to the shop Tom ill let the guys know and keep u guys updated
Old Dec 29, 2012 | 09:11 AM
Smashboogie 4x4's Avatar
Former Vendor
Good luck! Make sure you let us know what the shop tells you.
Old Dec 30, 2012 | 11:02 AM
Omani2010's Avatar
Ok guys just got back from the shop
Took my lady there and they found out that my steering stabilizer
Had a leak on it so I got that changed
And I was running on stock rims with the old tires which
Made the problem even more
I was lucky that I found the tires I was looking for
So changed them
And so far problem solved hope that
"death wobble" never comes again
The ride feels solo much smooth now
