Coil spring/shock change and spacer question
Old Dec 31, 2012 | 04:58 AM
deertick's Avatar
Default Coil spring/shock change and spacer question
so i want to change my springs to the stiffest ones mopar makes which i think are 19/60s if i remember right? my fronts currently are 14 and i forget what my rear is but i really want it to sit higher. i was thinking of swapping out the springs for stiffer ones then getting the AEV 2" spacer kit. if i do those two things will i or should change the shocks? and will i run into any problems with having taller springs since they'll be stiffer and the spacers not fit? currently i am running stock rubi wheels and tires and are planning on changing that either if that's a factor
thanks!!
-Tom
Old Dec 31, 2012 | 05:19 AM
catahoula's Avatar
thanks!!
-Tom
Hi Tom,
There are members running 4 dr springs with rubi shocks. You might look at shock adapters or new shocks, but I have seen members running Rubi springs and shocks for a 4dr with leveling kits such as Teraflex and no adapters.
I wnet from 14/55 to 18/59 springs and Rubi shocks, wheels and tires. Including 1.5" Spidertrax spacers. Very happy with results. I will add leveling kit down the road.
Before
After
Old Dec 31, 2012 | 05:21 AM
jadmt's Avatar
JK-Forum Ambassador
thanks!!
-Tom
there will be no issue with combing the aev 2" spacer lift and stiffer springs as some jeeps come stock with 19's. Better shocks are always a good idea but rubi shocks are good shocks for oem
Old Dec 31, 2012 | 06:00 AM
Gman*2007's Avatar
thanks!!
-Tom
Hey Tom, I'm running 3" level kit with 19/60 springs and Rubi red shocks. Very happy with this set up.
Old Dec 31, 2012 | 06:22 AM
catahoula's Avatar
Pics please
Old Dec 31, 2012 | 06:23 AM
deertick's Avatar
very awesome! that's exactly what i want to do so im glad there wont be any issues! are the rubi shocks good or should i go with something like bilstein?
Originally Posted by catahoula
Hi Tom,
Before
Attachment 403838
After
Attachment 403839
Old Dec 31, 2012 | 06:56 AM
catahoula's Avatar
I've read awesome results from forum members that have Bilsteins. Rubi shocks are very nice and budget minded can be had for around $100? Here is another angle
Old Dec 31, 2012 | 07:11 AM
catahoula's Avatar
I also got pics of me next to a 2Dr 2013 rubi if you want to see for comparison let me know.
Old Dec 31, 2012 | 07:31 AM
Jeepin Dad's Avatar
you will be adding 3.5"-4" of lift with the longer springs (higher number springs are physically longer not stiffer) and spacers, you can stick with stock shocks but you will really be limiting your down travel if you are planning on off roading. I went from 14/55 to 17/58 along with 2" spacers, even the longer shocks that came with the 2" BB were limiting my down travel, I am currently running Bilstien 5100's for a 4" lift up front and a 3" lift in the rear. I did need to extend my bumpstops and brake lines.
17 vs 14 spring 1.5" taller
Here is mine
With old shocks only 3 tires on the ground
longer shocks all 4 tires remain on the ground
Old Dec 31, 2012 | 08:31 AM
deertick's Avatar
yes please!!! love to see that!!
