Steering wheel jerks after i hit a bump.
Old Jan 1, 2013 | 11:21 AM
JasonM's Avatar
I lifted my rubicon 3.5 inches. Running 35 inch tires. My problem is that if i hit a bump doing between 20-30 mph my steering wheel jerks. It doesnt do it at higher speeds. What is going on?
Old Jan 1, 2013 | 12:59 PM
afpilot82's Avatar
JK-Forum Ambassador
I hate it when my Jeep hits a dong...messy!
Old Jan 1, 2013 | 03:30 PM
familytime's Avatar
JK Forum Regional Rep
Bump dong,sounds painful
Old Jan 3, 2013 | 02:39 PM
WranglerRush's Avatar
Maybe an aftermaket steering stabilizer would help you
Old Jan 3, 2013 | 02:44 PM
HornetJK's Avatar
Its called bump steer. The higher you lift your jeep the more suspension componants you will need to correct the geometry. I don't know what your current set up is, but start with control arms to correct caster and a drag link flip kit to correct your steering geometry.
Old Jan 3, 2013 | 02:45 PM
robsjeep9's Avatar
JK-Forum Ambassador
Track bar centered ? Adjusted right?
Old Jan 3, 2013 | 06:35 PM
Cedo Nulli's Avatar
All good inputs above, but with a solid front axle, you'll never completely get rid of bump steer. A new dampner/stabilizer may help, along with a drag link flip.
