Fabricated Top Hoist
Old Jan 1, 2013 | 03:43 PM
jpm1074's Avatar
Default Fabricated Top Hoist
Has anyone fabricated a top hoist for a JK three piece 4DR hardtop? if so can you share plans-ideas. I was looking at the hardtop hoists from the retailers but it seems like there isn't that much to them for the price.
Thank for help in advance!
Old Jan 1, 2013 | 03:59 PM
HG07JKRubi's Avatar
[h=3]Hardtop hoist/storage write-up[/h]
Old Jan 1, 2013 | 04:00 PM
bob134's Avatar
This is what I made maybe it will help you
Name:	Jeep Top Lift 002.jpg
Old Jan 1, 2013 | 06:49 PM
whiskey_golf's Avatar
I used the write-up that HG07JKRubi linked as a template and instead of the gusset plate used a sheet of 1/4" plywood to make a shelf on top of the T shaped hoist. I put a 2x3 fence around that so it holds my Freedom Panels on top. I also ditched the chain supported shelf since my garage ceiling is ridiculously high, I just hang it up above everything.
The only downsides are that I have to use sandbags to balance it when the top is not hanging beneath it and the rear hook is lengthened by a coupling nut and it bothers me that I can't tell how many threads are engaged.
Old Jan 10, 2013 | 01:49 PM
jpm1074's Avatar
Default Top warpage
Has anyone had top warpage issues? I will most likely leave the hardtop on the hoist for the summer and I have been reading about warpage problems.
Old Jan 10, 2013 | 02:09 PM
JK-Ford's Avatar
Then you should go one step further and build a shelf for it to rest on. I wouldn't suggest leaving it suspended from a hoist.
Old Jan 10, 2013 | 02:26 PM
TXBeachJK's Avatar
This is my cheap setup I use. Just gotta make sure you get the hooks into studs. I leave mine hanging like this every year from March until November. I haven't had any issues with warping.
ID:	407997   Click image for larger version
ID:	407998   Click image for larger version
Old Jan 10, 2013 | 02:37 PM
KCTW's Avatar
This is probably more extreme than you want to go, but I redesigned the trusses in the garage and hoist the top up into the rafters. I ues a cable and pully system up in the attic that comes out at the front of the garage above the garage door. I then back the jeep in the garage, and use the winch on the jeep to hoist the top up in the rafters. It works great and I can remove and install the top by myself.
ID:	408001 Click image for larger version
ID:	408002 Click image for larger version
ID:	408003 Click image for larger version
ID:	408004 Click image for larger version
Old Jan 10, 2013 | 02:54 PM
JK-Ford's Avatar
Originally Posted by KCTW
This is probably more extreme than you want to go---
Cool idea. did you do anything besides head off the joists?
Old Jan 10, 2013 | 04:02 PM
Patman's Avatar
https://www.jk-forum.com/forums/stoc...4/#post3198811
start at post #5
Mine is up there 9 months a year. I've done this for two years, and just put my hardtop back on before christmas and it fits like new. I keep my panels and miscellaneous other stuff on the supporting 2x10.
The 4 block and tackle set ups came from Northern Tool, and I used one 4' garage door hanger bracket and cut it with a hacksaw. When installing, I bolted the brackets to the studs in the ceiling and tried to keep them at each corner of the soft top (maybe a few inches out).
It's a one-man job to remove/replace the hardtop, and with the block and tackle I can raise and lower it with 1 arm.
