I need some to measure There 3in FT lift
Old Jan 18, 2008 | 11:54 AM
G Timmy's Avatar
Default I need some to measure There 3in FT lift
i need to know the hight between the center of the hub and the bottom of the fender after the install. I want to make wure my jeep will still fit in the garage after I put the lift on. and since there is so much varyation in tires this is the ony way to take them out of the equation. thanks!!
Old Jan 18, 2008 | 12:39 PM
wayoflifette's Avatar
JK-Forum Founder
I think you will get a wide range of answers depending on if you have a 2dr or 4dr, aftermarket bumpers or stock bumpers, winch or no winch. You might want to post up your specs so someone with similar specs could help you out.
Also, you might want to check out this thread:
https://www.jk-forum.com/forums/modified-jk-tech-2/full-traction-3-ultimate-actual-lift-height-25837/
