Swaybar light - Flash and ding
Old Jan 2, 2013 | 02:06 PM
DanBlan's Avatar
Default Swaybar light - Flash and ding
So this has happened several times in the last month or so. I'll be driving (2wd - usually around 80 - 100km/hr) and all of a sudden, I hear the "ding" tone and see the swaybar light come on briefly. I've searched but have yet to find a reason for this. Any insight is appreciated.
2012 - JKUR with 3" lift and 35's.
Old Jan 2, 2013 | 06:56 PM
DanBlan's Avatar
Bring it on up!
Old Jan 3, 2013 | 04:16 PM
DanBlan's Avatar
Anyone Anyone Anyone???
Old Jan 3, 2013 | 05:10 PM
gunbo75's Avatar
I know this happens when it seems like you're on the highway but do you have any problems disconnecting it and then reconnecting at in 4 wheel drive my guess is you have a ruby I have an X with the factory disco what year Jeep you have.
Old Jan 3, 2013 | 06:52 PM
DanBlan's Avatar
It's a ruby and I don't seem to have problems disconnecting or reconnecting.
Old Jan 3, 2013 | 08:25 PM
Jersey_Devil's Avatar
It's gonna just keep giving u problems.... Ur not the only one.... Save urself the same headache that some of us do and take this advice......
Buy this http://www.offroadevolution.com/stor...d=EVO-NOLIMITS
Then go on ebay and buy a "procal" for ur jeep (this corrects ur speedometer for bigger tires, clears codes, AND turns off that pesky sway bar light)
Cuz now ur disco is manual but it's just turn a knob and it's disco or no disco. Any DIY mechanic can install this too.
U will NEVER EVER see that light come on again! And but will have the security of knowing that ur not disconnected at 80km for some reason
Otherwise u will either keep going to dealers for warranty work or paying to fix electronic parts all the time..... Ur choice. I did it on the first sign of a problem with my electronic disco
Old Jan 18, 2013 | 10:24 AM
Hohertz's Avatar
Buy this EVO: Suspension / Steering, NoLimits Manual Rubicon Swaybar Disconnect
Do you know if a superchip flashpaq will clear the sway bar light? Thanks
Old Jan 18, 2013 | 11:19 AM
Sparkplug's Avatar
Do you get any gauge movement or just the swaybar light? I get flashing lights and gauge movement sometimes. No idea where that's coming from.
Old Feb 11, 2013 | 08:03 PM
Mcgee149's Avatar
Mine is doing the same but upon further inspection there is evidence of a fun weekend....broke the electrical connection to my motor. I ordered the EVO piece today.
Old Feb 11, 2013 | 08:25 PM
Batman's Avatar
Most likely a bad ground. had the same thing, poured over all the forums and found a few others with the same issue. i redid all my wiring and havent had an issue since
