3" Teraflex coil lift
Old Jan 2, 2013 | 03:15 PM
Bxjk's Avatar
Default 3" Teraflex coil lift
My question is I am upgrading from a teraflex 2.5" coil lift to a 3". What size sway bar links do I need for the rear ? Or could I use the front links from my 2.5 lift ?
Any help is greatly appreciated.
Old Jan 2, 2013 | 03:44 PM
gunbo75's Avatar
I have a teraflex 2.5 coil lift and a 1"spacers pucks all around and i have the same links in the back and no problems here.you do have the 2.5 links in the back now yes
Old Jan 2, 2013 | 03:55 PM
Bxjk's Avatar
Yes. I swapped the stock rears to the front and installed the 2.5" in the rear.
I contacted teraflex and they told me all I needed to make these coils work is extended brake lines and a new set of 3" sway bar links. Just not sure if they go in front or in back and vice versa.
Old Jan 2, 2013 | 04:16 PM
wolfla26's Avatar
I'm running the stock rears in the front with new ones in the back from my TF 2.5" coil lift. Currently running 3" synergy coils. No problems over here
Old Jan 2, 2013 | 04:23 PM
Bxjk's Avatar
Ok. Thanks wolfa
