35x12.50r17 Falken Wildpeak AT
Old Jan 3, 2013 | 01:18 PM
bleleux3's Avatar
Default 35x12.50r17 Falken Wildpeak AT
Can someone please measure the height and width of this tire? I'm about to purchase these tires but want to make sure they are a true 35" tire.
Thank you in advance guys!
Old Jan 3, 2013 | 01:48 PM
keithvegas's Avatar
At 32 psi under load they stand just under 34". They are about the same height as a km2.
Old Jan 3, 2013 | 02:50 PM
1904JK's Avatar
Anyone know the weight of this tire?
Old Jan 3, 2013 | 02:59 PM
Tonka_yellow's Avatar
The Falken website should have the weight of each tire
Old Jan 3, 2013 | 03:00 PM
keithvegas's Avatar
It is listed as 75 lbs.
Old Jan 3, 2013 | 03:30 PM
1904JK's Avatar
Yeah thats what i got to was 75 lbs. Im trying to figure out if this is to heavy for the
jk or not? Why are people running such a heavy AT tires when u can get others that are nearly 10lbs lighter?
Old Jan 3, 2013 | 03:47 PM
keithvegas's Avatar
Better side walls. If you are looking for a solid tire that performs well on rocks but is quiet on the road it is a great choice. I ran them at 10 psi on the rocks because they have very stiff sidewalls and never lost a bead. The weight really isn't that much of an issue once they are rolling. I even hung my spare off the stock carrier for 4 months without a problem.
They do pack up in wet sand and I've heard they aren't great in mud though.
This should give you an idea of what I've put them through.
http://youtu.be/uBKczNYHeLI
Old Jan 3, 2013 | 04:53 PM
1904JK's Avatar
Nice pics and thanks for the info! Thats pretty much what everyone said to but wasn't sure if weight was that much of a deal breaker.
Old Jan 3, 2013 | 05:25 PM
Rancho's Avatar
Sponsoring Manufacturer
I am stealing #2. ; )
Originally Posted by keithvegas
Better side walls. If you are looking for a solid tire that performs well on rocks but is quiet on the road it is a great choice. I ran them at 10 psi on the rocks because they have very stiff sidewalls and never lost a bead. The weight really isn't that much of an issue once they are rolling. I even hung mine off the stock carrier for 4 months without a problem.
This should give you an idea of what I've out them through.
Attachment 405273
Attachment 405274
Attachment 405275
Holcomb Teaser - YouTube
Old Jan 3, 2013 | 07:09 PM
JeepDawg72's Avatar
They are heavier which as pointed out above is larger attributed to stronger sidewall, but the tread pattern also has an incredibly low rolling resistance so you will usually gain MPG versus other AT's and definitely versus MT's.
There are a couple of threads with more details on MPG from the Wildpeaks.
The price is hard to beat too.
