I know the JK d30 uses the same ARB's as TJ d30, but......
Old Jan 18, 2008 | 04:31 PM
rockwerks's Avatar
Default I know the JK d30 uses the same ARB's as TJ d30, but......
...what about the shafts? is the JK the same track width as the TJ? will the shafts fit or is the JK a wider track? What is the WMS TO WMS for the JK front axle?. Sorry for all the Q's but trying to hook up a friend who owns a JK with some parts
Old Jan 18, 2008 | 04:32 PM
Piginajeep's Avatar
it isnt going to work, not a chance
Jk's wider
Old Jan 18, 2008 | 04:37 PM
rockwerks's Avatar
Jk's wider
Do you have dimensions or just pulling the info out of the air? what about the stub shafts?
Old Jan 18, 2008 | 04:54 PM
Piginajeep's Avatar
the Jk's 61.9 stub to stub.
the TJ"s 61
If they we're the same, Axle companies such as Superior would already have them out. They are just now getting them done for the D30 760 U-joint.
On the JK rubicon it has a larger U-joint. Its like a 760 U-joint, same size cap, its just longer than the 760.
Old Jan 18, 2008 | 05:14 PM
rockwerks's Avatar
the TJ"s 61
TJ is 61.5 wide so is the ZJ and XJ IVe been building them for years..........Im wondering why the change to a different U joint? better steering maybe????
I know the stub shafts have the same spline count but are different some how???
Well atleast he can use the 30 spline ARB and we can have new shafts made...
Old Jan 18, 2008 | 05:27 PM
Piginajeep's Avatar
Ok, 61.5, I read two different measurement online for the TJ. I went with the one I seen the most, Either way its different.
No idea, maybe so people would have to buy Mopar and not after market?
I have a stub shaft from my D30. If you want me to measure or take some pictures. I dont know the difference.
theres also issues with using ARB lockers in the rubicon's. the stock e-locker has an offset locating pin, unlike the aftermarkets. So if you run an ARB in the JK axle shafts will binding up.
(Call superior about using the ARB on the D30. I talked to them yesterday and found out the info above)
Old Jan 18, 2008 | 06:05 PM
rockwerks's Avatar
his is not a rubi but an X so that should not be an issue. according to ARB anyway LOL.....today anyway............yep if you could take some measurements basically the stub shaft length from cotterpin hole to where it sits against the bask side of the unit bearing.
Old Jan 18, 2008 | 06:19 PM
IGOFSHN's Avatar
Rubicons have D44's not D30's. he is asking about D30's. the arb will work in the JK 30 but the shafts are different.
Old Jan 18, 2008 | 06:20 PM
Piginajeep's Avatar
No shit, I was just informing him of other differences..
Did you not read the whole thread and see I was not just talking about the D30?
He's also asking the difference between TJ axle's and JK axles...
Old Jan 18, 2008 | 06:26 PM
Piginajeep's Avatar
No problem, I'll try and get to that tommorrow..,
