Oil consumption FIX
Old Jan 4, 2013 | 03:23 PM
JKJeepJunkie's Avatar
Default Oil consumption FIX
So I know a guy, who know a man, who is related to this guy who works for the local Dodge dealer who just so happens to also be a close friend of mine who give me some advise about the 3.8/3.6 "using oil" problem he says that the factory recommended oil for are jeeps is 5w-20, (TRUE) they say " its whats best for the motor" (FALSE)
Straight out of the dealers mouth he says " most people complain or have had some issue of some kind with having to add about 1/2qt to 1 quart every oil change and they believe its something wrong with the motor, its not its with the oil, the 5w-20 is so thin it seeps by the rings (blow-by) and is burnt off during combustion"
Run a thicker oil like 10w-30 and you will be fine no more adding oil
Old Jan 4, 2013 | 04:07 PM
gunbo75's Avatar
Good to know but what about the guys with the unlimited powertrain warranty.if they find out i am using a heavier oil then what.
Old Jan 4, 2013 | 04:38 PM
JK-Ford's Avatar
Hard to trust a friend of a friend of a friend. Even if your just protecting someone's identity.
Old Jan 4, 2013 | 04:42 PM
StuFarmer's Avatar
10/30 Mobil 1 since 2nd oil change. Zero motor sounds.
Old Jan 4, 2013 | 04:46 PM
JK-Ford's Avatar
I've been running the OE recommended 5w/20 for the last 95,000 miles without any issues. But I think that recently my luck may have changed.
Old Jan 4, 2013 | 05:54 PM
No im not protecting anybody lol it was just to be funny
But its only some motors that do it not all of them that probably why your not having problems i have an 08 with 41,000 and i don't have any issues either i was just relaying the info #beer
Old Jan 4, 2013 | 05:55 PM
After you run your oil awhile it will get thinner i dont think they can tell but thats just my guess im not for sure #thinking
Old Jan 4, 2013 | 06:08 PM
ronjenx's Avatar
Yeah. OK. There is no fix-all for the oil burners.
Some need thicker oil; some need new rings; some need a whole new engine; etc.
Old Jan 4, 2013 | 06:17 PM
Ryan0260's Avatar
Agreed. The thicker oil will only work to some extend. I do agree these motors like thicker oil though
Old Jan 4, 2013 | 06:21 PM
ronjenx's Avatar
As do I.
