07' Rubi with stock -> to 35's...need to lift?
I have a 2 door Rubi, and want to put 35's on her...I would not mind going down to 16in wheels, but do I need to do a full suspension lift to fit the 35in tires on?sorry for the newb question, but I have had sportscars my whole life...until I got my Rubi few months back due to moving to Seattle and loving the places I can get to up here...
Thanks!
Oh, and as stated above, check out the FAQ section. It's loaded with great info...
TF 2.5" BB with 35's, no rubbing at all...You will need either wheel spacers or after market wheels with 4.7" or less backspacing. A rear track bar drop bracket, or adjustable track bar is also recommended to prevet the inner sidewall of the rear driver's side tire from rubbing on the sway bar at full droop.
