tweaking stock suspension
Just curious who all is running the currie heim joint rear swaybar links. Also does anyone have measurements of the stock front shock lengths? I know the stock rubicon travel in the rear is 8.5 inches (14 closed 22.5 extended length). Not sure on the front. I'm tempted to buy the currie long travel rear kit. Comes with swaybar links, brake lines, and spring retainers. Just needs some longer travel shocks and I was wondering how much up travel the stock shocks have before bottoming out. My idea was to relocate the lower shock mount on the rear up 2 inches and rock the stockers till I lift it and put better shocks on it. And I didn't want to blow out the stock shocks by bottoming out the shock when it stuffs a tire.
