Rancho brake line relocation bracket bent (pic inside)
Old Jan 7, 2013 | 12:59 PM
j0ew1120's Avatar
Default Rancho brake line relocation bracket bent (pic inside)
Has anyone experienced this? I was doing a bolt check and stumbled upon this this morning... It was actually bent more but I bent it back some with a pair of pliers. Did I maybe install it wrong? Hmmm
Old Jan 7, 2013 | 01:08 PM
Chaffin1's Avatar
Is this your front or rear brake line, and what size lift are you running. I'll go check mine and see if it looks bent.
Old Jan 7, 2013 | 01:13 PM
j0ew1120's Avatar
This is the 4inch sport lift with the 9000 shocks. The pic is of my front passenger side.
Old Jan 7, 2013 | 01:18 PM
Chaffin1's Avatar
Mine came with extended brake lines for the front, so I don't have the bracket in the front. I have those brackets on the rear. Mine is the 3" sport.
Old Jan 7, 2013 | 01:24 PM
j0ew1120's Avatar
Hmm, maybe Rancho could chime in here. If your out there.... (Weird e.t. voice)
Old Jan 7, 2013 | 02:16 PM
Fan45acp's Avatar
Looks to me like the brake line should be routed behind the front shock..
Old Jan 7, 2013 | 03:14 PM
gunbo75's Avatar
Yep x2 on that brake line .
