Gearing question, ratios are not making sense
Okay, So im moving up to 35s in the next few weeks. I noticed alot of people recommending 5:13s, Now my JKU came from the factory on 32s and 3:73s, was factory gearing way under cut? according to a genaric calculator it says my Gearing to go back to current state should be 4:10s? if thats the case wouldnt 5:13s be way to tall for DD use?
I was researching the same tire change and with the auto trams it seems the 5:13s are the way to go. Everyone with their manual tranny Rubicon are typically able to run their 4:10s just fine they just adjust their shift timing.
Do you have a 2012+ or a 2007-2011?
Is it an automatic or manual?
If 2007-2011 automatic: a lot of people go with 5.13, at highway speeds it is pretty decent and not too high in the RPMs, nice around town
if 2007-2011 manual: I hear of a lot of people sticking with stock (3.73 or 4.10) or going to 4.56, with 4.10 seeming to be the sweet spot with 4.56 being a bit of a lower gearing from what I gather.
if 2012-current automatic: 3.73 should be just fine for 35's, ideally 4.10's would be the sweet spot.
if 2012-current manual: I believe 4.10s are the sweet spot here for the manuals as well, with 4.56 being a smidge high.
These are rough guesstimates. For more information check out this post:
https://www.jk-forum.com/forums/modi...17/#post211276
(scroll down until you see the charts) These should give you some handy information on all of it.
https://www.jk-forum.com/forums/modi...-205615/page2/
Gearing chart --- '07 to '11 3.8L - post 20
On my '12 automatic, 3.6L , 35" --
The 4.1 gear ratio is good. On roads the overdrive kicks in, and there's plenty of power for offroading.
I wouldn't go beyond 4.56, unless it's for extended slow technical offroading.
Christarp said it best: Depends what year and transmission you have.
Also consider the bigger tire will jump in weight, especially due to added width. You can't just consider the gain in height.
I agree also with Christarp. However make sure to consider the real purpose for your regear. I went to 35's and 4:88's here in Ohio on my DD. I use it a lot in SE Ohio which is pretty hilly as well as toe my 8x12 ATV trailer without any issues at all. W/O toeing my trailer, down shifting for the hills is very rare. Toeing my trailer, loaded, I can hold 65 all da long. I also get really decent milage. If your wanting to maintain factory to near factory RPM's, milage, etc, then 4:56's are the way to go.
Good luck with whatever way you chose.
