4" rancho shock on stock jk
Old Jan 9, 2013 | 01:30 PM
xavier lord's Avatar
Default 4" rancho shock on stock jk
is this even possible i have 1 set of ranchos 9000 adjustable shock from a 4"lift kit and was thinking if they fit
Old Jan 9, 2013 | 01:41 PM
k0260's Avatar
With that long of a shock body, you'll have minimal up travel
Old Jan 9, 2013 | 01:57 PM
Rancho's Avatar
Sponsoring Manufacturer
Have a part number by chance? Just to confirm for a 4". I am sure it is...
Old Jan 9, 2013 | 06:47 PM
dont have right now but it came with a 4" lift kit
Old Jan 9, 2013 | 08:06 PM
Delux2769's Avatar
My 4" Rough Country shocks were fully compressed on stock springs (i test fit them). Even parking lot speed bumps would overly compress the shocks.
I would suggest either lots of bump stops. Or at least some coil spacers until you can put on the 4" springs.
You will have some MASSIVE down travel.
Old Jan 9, 2013 | 08:08 PM
k0260's Avatar
with no lift and that long of a shock, the short up travel will have the shocks bottoming out, won't be able to get that down travel.
Old Feb 18, 2013 | 07:18 PM
cis911's Avatar
Don't forget that with that long of a shock your coil springs might fall out. I say you cycle your suspension with the new shocks and see what happens. I had a 2.5" BB (stock springs) with shocks that were for 6" lift from skyjacker and out worked out great!!!! I did add .75" of bump stop.
