What shims on a new housing?
Old Jan 9, 2013 | 02:12 PM
xj2jk's Avatar
Default What shims on a new housing?
I purchased an empty front D44 housing from a rubi. I am going to be installing a locker and 5.13 gears. From what I have read, when setting initial shims for the carrier and pinion gear, you are supposed to use the old shim thickness as a baseline and adjust from there. Since I have a new empty housing, I am not sure where to start. Does anyone have an idea of what shims I should use to get started?
