Need some help...
Old Jan 10, 2013 | 08:54 PM
ze9900's Avatar
Default Need some help...
I was driving my Jeep home from work this afternoon and this light came on Click image for larger version
I tried recentering my steering wheel, using my procal to clear all codes, and I even checked the on board computer. Anyone have any idea how to fix it?
Its a 2012 with approx 12k miles. I recently put Rubi coils on it.
Thanks ze9900
Old Jan 10, 2013 | 09:07 PM
Z.A.Kenworthy's Avatar
that happens to me all the time when the roads wet or its windy out, i dont know why it does that but eventually it just goes off.
Old Jan 10, 2013 | 09:09 PM
planman's Avatar
Forum Tech Advisor
It may reset overnight. Sometimes, if you have been driving on slick roads, that traction control error shows up.
Or, you could disconnect your battery overnight to see if the code clears (if you do, you would need to reset your clock, etc.).
Old Jan 10, 2013 | 09:14 PM
ze9900's Avatar
Well it rained most of my way home. Do hopefully is will fix itself. Thanks for the quick replies
Old Jan 10, 2013 | 09:57 PM
Canibeat's Avatar
If it's you're steering wheel you'll get EAS/BAS as well... at least that was in my case...
Old Jan 11, 2013 | 08:54 AM
ze9900's Avatar
An update...
Autozone couldn't read the Jeep. To new
I have an appointment Monday afternoon.
Old Jan 11, 2013 | 09:00 AM
janders82's Avatar
Originally Posted by ze9900
An update...
FYI, the ProCal won't be able to center your steering wheel which the tires on the ground. Have u adjusted for tire size using the ProCal?
You can do the key dance trick to see if you're throwing any codes
Old Jan 13, 2013 | 07:11 PM
ze9900's Avatar
Well last night I had to go to a wedding that was roughly an hour away. Made it there the light stayed on the whole way, about 5 miles into return trip home the light kicked off. So I don't know if it was because the steering wheel was off for 25 miles and caused the traction control light to come on, then I centered the steering wheel and had to drive it around to make the computer happy? Hope this helps someone else who has the same type of trouble later on...
Old Jan 13, 2013 | 07:12 PM
ze9900's Avatar
Yes I've adjusted my tire size. I did the key dance and it didn't show any codes.
Old Jan 13, 2013 | 08:15 PM
jadmt's Avatar
JK-Forum Ambassador
how off was your steering wheel with just changing the coil springs?
