How so small my car jack..
Old Jan 19, 2013 | 04:11 PM
tkkim's Avatar
Default How so small my car jack..
I bought 4 ton car jack from harbor freight and just got it.
And it is way to small... My jku is lifted 2.5'.. I lift my jack as much as i can.. But even i can touch any part of my bottom..
http://www.harborfreight.com/4-ton-h...ack-66450.html
Mine is this..
Did i buy wrong one?
Usually 3.5 of 4' lifted jeep owner what kind of jack use?
Old Jan 19, 2013 | 04:21 PM
JKbender's Avatar
Put the jack under the axle rather than the frame.
afpilot82's Avatar
JK-Forum Ambassador
I would take it back and just use your factory scissor jack with the AEV base or a piece of 4x4 to give it some extra height. Read this thread, started just a couple hours ago.
https://www.jk-forum.com/forums/modi...ptions-261083/
Old Jan 19, 2013 | 04:25 PM
Gman*2007's Avatar
I've got 3" lift with 34's and the AEV base with the factory scissor jack works great on the axle. (not the frame) If you have after market bumpers you could use a hi-lift jack.
Old Jan 19, 2013 | 04:29 PM
tkkim's Avatar
Under axel mean is under differential cover?
Old Jan 19, 2013 | 04:33 PM
finfreeze's Avatar
More towards the wheel on the axle tube.
Did you unscrew the top of the jack? It should have a threaded adjustment.
Old Jan 19, 2013 | 04:38 PM
JKZinger's Avatar
Take it back and buy a floor jack. 3 ton
Old Jan 19, 2013 | 04:45 PM
k0260's Avatar
Go with a good floor jack and an aev base for keeping in your jeep. My aev base works awesome. Bottle jacks are terrible.
Old Jan 19, 2013 | 06:14 PM
tkkim's Avatar
Could u recommend me some good floor jack?
Old Jan 19, 2013 | 06:20 PM
k0260's Avatar
Sure, here is the one I use. Affordable around $80, works great. Up to 21". Or buy a larger floor jack, better for higher price though. This duralast suv jack works perfect for me. 1Duralast/2 1/2 Ton SUV jack (T83006FZ) | Jack | AutoZone.com
