draglink bushings
Old Jan 21, 2013 | 12:06 PM
Rich30000's Avatar
Default draglink bushings
Can I buy the drangkink bushib gs without buying the draglink bar ? When I wreak on the ice and hit the sidewalk. The draglink has a lot of play .
Old Jan 21, 2013 | 12:10 PM
chris@offroadevolution's Avatar
Sponsoring Vendor
You can buy the TRE on the pitman arm seperate, but the actual tie rod from the knuckle to the adjuster collar is one piece
Old Jan 21, 2013 | 12:15 PM
Rich30000's Avatar
The sterring is causing the traction control to come on. And grab the jeep my guess and this is what a fellow jeeper told me. The draglink has to much play from the pitman arm.
Old Jan 21, 2013 | 12:18 PM
Sponsoring Vendor
Have you recentered your steering wheel?
Old Jan 21, 2013 | 12:26 PM
Rich30000's Avatar
Yeah just had it aligned. But I can move the draglink up and down like nothing I assume the extra play is casing the traction control to come on .. where can I just buy the bushing or even better grease fittings
Old Jan 21, 2013 | 12:29 PM
Sponsoring Vendor
Even if you had it aligned, it might not be right. You can buy a new draglink or tie rod at the dealer.
Here's how you can recenter your steering wheel
Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Old Jan 21, 2013 | 12:35 PM
Rich30000's Avatar
So I will need to buy the draglink bar. Does it come with the bushings.
