PSC hose routing question
Old Jan 21, 2013 | 04:01 PM
meatsandwich's Avatar
Default PSC hose routing question
I just installed the full PSC system with their gearbox.
I'm at the system bleeding portion, and had some binding on the first start. It was hard to tell if it was just air in the system, or if my pressure lines are backwards. The PSC instructions do not specify where the driver's side hose on the ram connects to the gearbox. It just says "most applications" have that hose connecting to the port closest to the firewall.
Can someone with this system confirm where the lines route?
Thanks!
Old Jan 21, 2013 | 05:29 PM
familytime's Avatar
JK Forum Regional Rep
Looking at the steer gear,the port nearest to the firewall goes to the driver side of the ram(piston end/moving)
