Bump stops
Old Jan 22, 2013 | 05:34 PM
jksearles's Avatar
Default Bump stops
I have a jku with 35s 3 inch suspension lift, 1 3/4 Teraflex spacers and body lift. When me and a jeep buddy I met on here installed my suspension lift he told me he didn't use bump stops and that we didnt need to Install them or even keep the stock ones because it would limit my articulation. Is this true and what pros or cons are there to not running any?
Old Jan 22, 2013 | 05:36 PM
kh202's Avatar
I don't know but that sounds like an assload of lift for 35's!!!
Old Jan 22, 2013 | 05:39 PM
jksearles's Avatar
That it before the body lift. I think it looks good. Im going to 37s next year once these are done
Old Jan 22, 2013 | 05:42 PM
rcdude3's Avatar
You might be fine...just make sure your coil springs do not collapse onto them selfs when you fully flex. There should be some gap between the spring coils.
jksearles's Avatar
So has a warn rock Krawler stubby front bumper and winch and rear rugged ridge xhd on it now
Old Jan 22, 2013 | 06:25 PM
kh202's Avatar
Looks good man. Just sounded like a lot with the lift, spacers and body lift lol.
Old Jan 22, 2013 | 06:35 PM
Atch's Avatar
You should run bumpstops. By not running them you're shortening the life of your coils & shocks
Old Jan 22, 2013 | 06:40 PM
familytime's Avatar
JK Forum Regional Rep
You need bump stops,they will help out in up travel limiting,keep from rubbing where you don't want
