2..5" Kit Installed with 37s and it ripped my fender off!
Guys Halp!
I installed a 2.5" Budget boost and it ripped my rear fenders right off. I knew i had to do some trimming so I did it and then i woke up after my drunk wheeling fest and it ripped my fender right off
can you guys halp?
can you guys halp?
1. Don't wheel drunk
2. A 2.5" bb will not clear 37" tires
Btw check your rear tires and make sure the pinch seam didn't cut up the tires.
Just leave them off... at least until you raise the Jeep and trim the fender flares. A Rock Krawler or TeraFlex 2.5" lift can get you by as long as you don't go extreme drunk wheeling. Of course a 3.5" lift would be better but then you may have to upgrade your drive shafts.
Good luck.
Good luck.
Not sure if I want to drive next to people who are not drunk but do pass out while behind the wheel. ? . Seems like 3" and above are needed to clear 37s. And I'm reading that pinion angles can make or break your tranny.
