34'' on stock carrier
Hey guys I searched and couldnt find what I wanted so here it goes! My 5 305/70/17 and XD addicts will be in tomorrow. Im putting a 2.5 Budget Boost in and was wondering if that size tire will mount to the stock carrier? Being a 4.75'' backspacing. Will i need a spacer? I plan on putting an aftermarket bumper and carrier eventually but cant afford it at this time.. Thanks! oh its a '12 jku
Should be ok without a spacer, I ran the same size tire on a stock rim using a 1.5" wheel spacer ( this would equal about the same back spacing as your aftermarket rim) and it fit fine. I am now running a larger 35x12.5r17 on a dc rim on the stock carrier with a slight rub on the bumper no spacer used.
Steve
Steve
Steve
Steve
I used a 1" wheel spacer. Got it about 1/4 inch off rear bumper and third brake light is fully visible. Add Daystar extended bumpstops, fits perfect.
Careful, u might break your tailgate, took 6 weeks for 5 welds to break on my tailgate. Ordered a ace rear bumper with carrier and was told 6-8 weeks to make, so I put my 315 on and 6 weeks later started hearing rattling then saw the damage. Might not of happened if my bumper showed up on time instead of 4 months later.
