what happened my rear wheel?
I installed spidertrax wheel spacer 1.5" two days before and I found this today.
this is driver side
this is passenger side
looks like different.. someone said it's adj trackbar problem..
what should i do?
and I measured from fender to top of tire and I found driver side is quarter inch higher than passenger side.
sigh... so confusing.
this is driver side
what should i do?
most likely putting the wheel spacers on, just made it more noticeable that the axle has shifted more to one side. Assuming you have a lift? Yes an adjustable rear trackbar will be needed to fix this.
Trackbar brackets help to keep your axle centered when lifting, but won't keep it exact, help raise roll center, and help reinforce your stock mount. To fix your current problem, you will need an adjustable rear trackbar. Roughly $165.
