Dana 30, 35's, and a locker?
Hi. Hoping to do the rubicon this summer with a few guys from the norcal section and im just wanting to know if i can get away with a locker on my dana 30 with stock gears. Im only running 35s. Maybe even going to beef up the axles. Any thoughts or suggestions?
Here are my thoughts; I sure would not. I have/had a Dana 30 with 35's and 4.88's no lockers. I was in the snow when I suffered my issue. Please see https://www.jk-forum.com/forums/modi...sounds-257299/
Ive read that the problems happen when you regear because the ring and pinion are weaker since your sticking to the stock gears it should hold up for a while gets some chromo shafts gusset the c's and wheel it till it breaks lol
Yeah sorry I assumed you had regeared. I am not sure how you will make out I think like everything else it depends how you plan to drive it. Easy on the skinny pedal and you may survive I know personally now I am on the 'DO NOT INVEST IN A DANA 30' band wagon.
I've been running an ARB locker and 4:88's for 5 years now in my Dana 30. Broke one universal joint. IMO you are better off with the locker so that u don't get the wheel spin and then the sudden catch of traction which is the cause of most breakage.
