Somethin is rattling
Old Jan 25, 2013 | 08:05 PM
jeepwave's Avatar
Default Somethin is rattling
09 jku with 3.5" lift and relatively new 4.88 yukons
There is a seriously annoying rattle that sounds like it's coming from right under my accelorater. In fact, i can make it happen if I hit the accelorater hard enough
I really don't think it's my tranny, didnt sound like it. It sounds more like a heat shield or something rattling away
Any thoughts? I know it's hard to guess without hearing it but I'm hoping someone might have an idea
Old Jan 25, 2013 | 08:23 PM
Jersey_Devil's Avatar
Did u check ur heat shields? That's more than likely what it is.
Old Jan 26, 2013 | 06:32 AM
k0260's Avatar
yeah x2, mine ended up being the heat shield on top of the exhaust pipe that runs parallel to your cross member. The 8 tack welds on there are known to break easily, 2 of mine were broken on opposing sides, so I just pried the shield up and out for less contact. Can't just feel by hand, gotta get under and pry around on it and you'll see the small seams lift up.
Old Jan 26, 2013 | 06:37 AM
agentcox000's Avatar
Yup same welds popped on mine. Re-tack weld them back down and you'll be good to go.
Old Jan 26, 2013 | 06:43 AM
Team Desert Eagle's Avatar
My 08 did the same thing. A couple of hose clamps around the heat shield at the weld locations fixed the rattle.
Old Jan 26, 2013 | 08:18 AM
Ryan0260's Avatar
X2. Easiest fix once you find the rattle
Old Jan 26, 2013 | 08:28 AM
maine07jk's Avatar
X3 on the clamps!
Old Jan 26, 2013 | 08:57 AM
jeepwave's Avatar
And I'm assuming we are taking about the heat shield up by the front part of my exhaust ?
Jeez I installed my mbrp offroad exhaust myself less than a year ago and I can't even picture this right now lol
